In-Ear Headphone Control and Mic Block Disassembly
Выберете то, что вам нужно
  1. In-Ear Headphone Control and Mic Block Disassembly, The Control Unit: шаг 1, изображение 1 из 1
    • Find the edge of the control unit and get a very fine flathead screw driver (or a plastic pry tool which would do less damage)
  2. In-Ear Headphone Control and Mic Block Disassembly, Opening The Unit: шаг 2, изображение 1 из 1
    • Wedge the tool in the corner and start sliding it to the left.
    • As you do this slowely twist the screw driver back and forth to release the clips.
    • Try not to let the tool slip into the control unit as this may damage the circuit board inside.
  3. In-Ear Headphone Control and Mic Block Disassembly, Removing The Cover: шаг 3, изображение 1 из 2 In-Ear Headphone Control and Mic Block Disassembly, Removing The Cover: шаг 3, изображение 2 из 2
    • Repeat step 2 and the control unit should open as seen in the image.
    • Remove the plastic sleeves and you will be left with just the circuit board (see second image).
  4. In-Ear Headphone Control and Mic Block Disassembly, Identify Broken Wire: шаг 4, изображение 1 из 1
    • It is quickly seen that one of the wires has broken away from the circuit board (see image)
  5. In-Ear Headphone Control and Mic Block Disassembly, Resolder the Broken Wire: шаг 5, изображение 1 из 1
    • Once the wire is found a steady hand and a fine tipped soldering iron should be used to reattach the wire.
    • Ensure that you do not head to circuit board for too long as it may cause damage (be as quick as possible!)
    • After this, the circuit board and wires should be replaced as they were before. Press the plastic cover halves together and it should click back into place.
    • And they are fixed!
Заключение
Your headphones should now be working!
4 участников успешно повторили данное руководство.
Alexander
Участник с: 09/10/18
260 Репутация
1 руководство автора
Один комментарий
Thanks a lot this worked perfectly thank you very much
MD Ratul - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 70
За последние 30 дней: 185
За всё время: 13,857
