Введение
This Metal Cover needs to be removed in order to replace most parts in the device.
Выберете то, что вам нужно
Turn the projector so that the lens is facing you.
Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
Remove the service cover.
Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
Use a Phillips #1 screwdriver to remove the two 5 mm screws.
Remove the top cover.
Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
Lift up the metal cover and set it aside to reveal the motherboard.
Carefully pry up the black plastic locking bar of the ZIF connector on the motherboard with a plastic spudger.
Pull out the blue-tipped, white ribbon cable from the connector.
Remove the metal cover.
