Введение
Instructional information on how to remove the top cover of the InFocus IN3104 projector for service.
Инструменты
Запчасти
Детали не указаны.
Turn the projector so that the lens is facing you.
Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
Remove the service cover.
Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
Use a Phillips #1 screwdriver to remove the two 5 mm screws.
Remove the top cover.
Почти готово!
Заключение
