Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will assist with replacing a non-functioning projector lamp, which is responsible for providing the light necessary for projection.
Выберете то, что вам нужно
Place the projector on its back with the control buttons facing down.
Remove the black 7mm screw on the external case with a Phillips 2 screwdriver.
Remove the 7mm screw near the bottom center with a Philips 2 screwdriver head.
Loosen but do not remove the 7mm screw near the upper right corner with the Phillips 2 screwdriver head.
Grab the silver handle.
Unhook the handle so it can move freely.
Pull the handle straight up until the lamp is completely removed from projector.
Еще один человек закончил это руководство.
