Введение
Replace the lens if you are experiencing a lack of an image when the projector is on.
You will need a replacement lens as well as a clean, micro fabric cloth in case the replacement lens needs to be cleaned.
Выберете то, что вам нужно
Flip the projector on its back.
Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
Turn the projector, facing the back cable board towards you.
Using the Phillips #0 screwdriver, remove the (3) three 1.0 cm silver screws on the back panel.
Gently take off back cable panel.
Turn the projector so the front side with the lens is facing you.
Gently pry the both of the grey lens rings using the metal spudger.
Now that the screws have been removed, proceed with the removal of the outer panel.
Gently remove the front lens panel.
Being careful not to pull the wires inside the projector, gently lift the top panel off the projector.
Using the Phillips #1 screwdriver, remove the (3) three 1cm black screws on the face of the lens.
Gently pull out the lens.
To reassemble the device, follow these instructions in reverse order.
Еще один человек закончил это руководство.
