Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the hex head bolt from the top of the access door on the pump head.
Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
Lift the pump handle until the base of the chain comes to rest on the spacer collar, and the chain is slack. Hold the handle in this position while the chain is being detached.
Using the two access holes, place an angled socket wrench on the bolt and nut attaching the chain to the pump handle.
Pull the top of the chain straight off of the pump handle.
Remove the two bolts from the handle side of the pump head.
Use one wrench on the bolt and another on the nut beneath. Hold the bolt stationary and loosen the nut.
After removing the two handle side bolts, have your partner support the weight of the handle.
Remove the two remaining bolts in the same fashion.
Slightly twist the head flange, until the corners overhang the top of the tank far enough to grab.
Slide the rod clamp around the pump rod, and support it on the tank base.
Unscrew the chain from the top of the pump rod.
Remove the chain.
Check the chain for signs of wear or damage.
Place a coupling over the pump rod, on top of the rod vise.
Screw the coupling onto the end of the riser main.
Use a pipe wrench to tighten the coupling onto the riser main.
Set the first lifting arm just above (but not touching) the pipe vise.
Add the other two lifting arms.
Ensure three things about the arms:
They must be equally spaced around the riser main (120° apart).
The arms must not touch each other, the coupling at the top, or the pipe vise at the bottom.
The openings should alternate, to keep the riser main secure.
As each person lifts up on their lifting spanner, they announce "got it" to let everyone else know they're holding.
Once all three lifters have announced that they've "got it," loosen the vise.
With the vise loosened, lift up the riser main 1-2 feet.
Lift only as high as everyone is comfortable.
Tighten the pipe vise, with the following procedure:
Announce "tightening."
Tighten the vise.
Announce "Tight."
Slide the three lifting spanners down on the riser main, into new lifting positions.
Once all of the lifters have said "got it," loosen the pipe vise.
Tighten the pipe vise, following the same verbal procedure.
Repeat the procedure several times:
Once everyone is securely holding the pipe, loosen the pipe vise.
Lift the pipe.
Tighten the pipe vise.
Slide the lifting spanners down to a new position.
Lift the riser main up through the pipe vise, until the coupling clears the jaws.
Tighten the pipe vise and move the lifting spanners down to a new position.
Lift the riser main high enough that there is room beneath the coupling for the three lifting spanners.
Use a pipe vise to unscrew the first section of riser main from the coupling.
Unscrew the upper section of riser main from the coupling.
Place the rod vise on the pump rod between the section of riser main.
Tighten the rod vise on the pump rod.
Use two wrenches to disconnect the upper section of pump rod from the lower section.
Once detached, lift and remove the upper sections of riser main and pump rod together, and set them down.
Screw the T-handle onto the newly exposed top of the pump rod.
Pull the assembly of riser main pipe and cylinder out of the well and set the assembly on a block of wood to keep the cylinder off the ground.
Using two pipe wrenches, unscrew the cylinder from the riser main.
Slowly pull the cylinder off of the pump rod, exposing the traveling valve and foot valve.
Using two pipe wrenches, remove the end cap from the cylinder.
Еще один человек закончил это руководство.
