Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Follow this guide to remove the head of the pump for repair or replacement.
Выберете то, что вам нужно
Remove the hex head bolt from the top of the access door on the pump head.
Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
Lift the pump handle until the base of the chain comes to rest on the spacer collar, and the chain is slack. Hold the handle in this position while the chain is being detached.
Using the two access holes, place an angled socket wrench on the bolt and nut attaching the chain to the pump handle.
Remove the two bolts from the handle side of the pump head.
Use one wrench on the bolt and another on the nut beneath. Hold the bolt stationary and loosen the nut.
After removing the two handle side bolts, have your partner support the weight of the handle.
Remove the two remaining bolts in the same fashion.
