Введение
Remove and or replace the head section of the India Mark II water hand pump.
Инструменты
Запчасти
No parts specified.
Pull the pump handle all the way down and hold it in this position, exposing the pump rod.
Place the spacer around the pump rod and under the chain attachment point.
Lift the pump lever until there is no tension in the chain and hold it in this position.
Remove the bolt connecting the chain to the pump handle.
Remove the chain from the handle.
There are 4 bolts securing the head section to the water tank, located at the corners of head section base.
Remove the 4 bolts on the base of the water tank.
Lift the pump head off of the water tank and place in a sanitary place, preferably above ground, to prevent contamination.
