Введение
Replace the antenna to receive better signal.
Выберете то, что вам нужно
Locate antenna connection.
Desolder wire to remove. An antenna of a new length can be soldered to the board for improved signal strength.
Еще один человек закончил это руководство.
2 Комментариев
That’s fine but what antenna did you purchase? My antennae wire is actually broken, started out with the plastic piece breaking then the cable snapped.
I would also like to know what replacement antenna you used.
