Введение
Disassembling the monitor allows for replacement of various internal components such as the charging port, screen, speaker, or antenna.
Выберете то, что вам нужно
Using the plastic opening tool, remove screen protector from front of monitor.
Remove the six 4mm screws using a Phillips #00 screwdriver.
Remove the screen, exposing the circuit board.
Turn device over to expose rear circuit board.
20 участников успешно повторили данное руководство.
27 Комментариев
Great walkthrough. One suggestion i have is to make sure to remove the battery before doing any of the disassembly. Great guide!
Any idea where I could buy a replacement screen though? I just dropped mine and the screen is broken. The front plastic is still undamaged.
I bought a Sharp LQ035NC111 LCD Display eBay for $8.46 and it did the trick
Do you know where I could buy a replacement screen for this device? I just dropped mine and the only damage that I can see is a crack in the LCD that is making the image almost entirely unviewable.
I replaced mine with a “3.5" Inch QVGA 240x320 TFT Color LCD Display Module LQ035NC111 54pin” I found on ebay for $8.81, works great.
