Выберете то, что вам нужно
Position the camera with bottom facing toward you.
Using the plastic opening tool, remove all four rubber ends from the bottom of the camera.
Remove the four 4 mm screws beneath rubber ends using the Phillips #00 screwdriver.
Disconnect the speaker cable from the circuit board for ease of access.
Lift the speaker from the casing using a metal spudger.
Place a new 8W speaker in the casing.
Почти готово!
Заключение
