Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
The disassembling of the monitor is so to be able to change the screen or replace other components of the monitor.
Запчасти
Детали не указаны.
  1. Start by gently inserting the plastic opening tool between the led and casing.
    • Start by gently inserting the plastic opening tool between the led and casing.
  2. Slowly pry the cover away from the bottom using the plastic opening tool.
    • Slowly pry the cover away from the bottom using the plastic opening tool.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Glide the tool around the entire cover to reveal the screws, which are 5.0 mm.
    • Glide the tool around the entire cover to reveal the screws, which are 5.0 mm.
  5. Remove the cover and set it aside.
    • Remove the cover and set it aside.
  6. Remove the four corner screws, 5.0 mm, using a J1 bit. Lift the top away from the bottom using the metal spudger. Be careful not to rip the antenna wire.
    • Remove the four corner screws, 5.0 mm, using a J1 bit.
    • Lift the top away from the bottom using the metal spudger. Be careful not to rip the antenna wire.
Заключение
6 участников успешно повторили данное руководство.
Larsha Johnson
Участник с: 26.08.2015
478 Репутация
Автор 3 руководств
Команда
USF Tampa, Team 6-4, Remmell Fall 2015 Участник USF Tampa, Team 6-4, Remmell Fall 2015
USFT-REMMELL-F15S6G4
4 членов
Автор 3 руководств
Комментариев: 2
What is the part number for the LCD?
jstarion - Ответить
From the pictures LQ035NC111 seem to be the part number.
Michael C -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 5,823
