Введение
The disassembling of the monitor is so to be able to change the screen or replace other components of the monitor.
Выберете то, что вам нужно
Start by gently inserting the plastic opening tool between the led and casing.
Glide the tool around the entire cover to reveal the screws, which are 5.0 mm.
Remove the four corner screws, 5.0 mm, using a J1 bit.
6 участников успешно повторили данное руководство.
