Инструменты
Запчасти
Детали не указаны.
Use a #0 Phillips head screwdriver to remove the four small black screws from the back of the device.
Once the screws have been removed, proceed to take off back cover.
Use a #0 Phillips screwdriver to remove the four small silver screws from the outside corners of the battery housing.
Now gently pry the front cover off. A Black Spudger can be used to assist in the removal of the cover.
Gently separate the mainboard from the battery housing. This may be difficult around the headphone jack. Use a spudger if necessary.
Pull the motherboard out and down away from the top of the phone.
