Initiate the instrument cluster self-test
Выберете то, что вам нужно
  1. Initiate the instrument cluster self-test, Save the headlights from excessive use: шаг 1, изображение 1 из 1
    • This procedure involves turning on and off the headlights repeatedly, which which can reduce the HID headlights' mean lifetime before failure. As a precursor, consider removing the 15A left & right low headlight fuses from the under-hood fuse box, positions 1 and 6. (Refer to your Owners Manual for instructions, or an iFixit guide.)
    • Be sure to reinstall the low beam headlight fuses before driving the vehicle.
  2. Initiate the instrument cluster self-test, Starting the self test inputs: шаг 2, изображение 1 из 3 Initiate the instrument cluster self-test, Starting the self test inputs: шаг 2, изображение 2 из 3 Initiate the instrument cluster self-test, Starting the self test inputs: шаг 2, изображение 3 из 3
    • Insert the ignition key into the ignition lock. Leave it in the 0 or I position.
    • Push and hold the Sel/Reset knob (on the instrument panel by the fuel gauge), or the Sel/reset button on the right hand of the steering wheel below the Multi-Information Display Info button.
  3. Initiate the instrument cluster self-test: шаг 3, изображение 1 из 1
    • Turn the headlights ON.
  4. Initiate the instrument cluster self-test: шаг 4, изображение 1 из 2 Initiate the instrument cluster self-test: шаг 4, изображение 2 из 2
    • Turn the ignition switch to ON (position II).
    • Some of the instrument lights will come on. If you aren't wearing your seatbelt, the seatbelt warning chime will sound.
  5. Initiate the instrument cluster self-test: шаг 5, изображение 1 из 3 Initiate the instrument cluster self-test: шаг 5, изображение 2 из 3 Initiate the instrument cluster self-test: шаг 5, изображение 3 из 3
    • Within five seconds, and still holding in the Sel/Reset button, turn the headlights OFF, then ON, then OFF again.
  6. Initiate the instrument cluster self-test, Final inputs, and here comes the show: шаг 6, изображение 1 из 3 Initiate the instrument cluster self-test, Final inputs, and here comes the show: шаг 6, изображение 2 из 3 Initiate the instrument cluster self-test, Final inputs, and here comes the show: шаг 6, изображение 3 из 3
    • Within 5 seconds, release the Sel/reset button.
    • Push and release the Sel/reset button button 3 times repeatedly.
    • The instrument cluster begins its self-test.
    • Each successive press of the Sel/reset button initiates a new cycling of all the gauges.
    • To end, turn the ignition switch to OFF, or vehicle speed exceeds 1.5 mph.
    • If you removed the 15A headlight fuses from the under-hood fuse box in step 1, reinstall them before driving.
Финишная черта
15 участников успешно повторили данное руководство.
David Spalding
Участник с: 11/12/15
6 461 Репутация
Автор 12 руководств
2 Комментариев
Folks, don’t post here asking about A COMPLETELY DIFFERENT VEHICLE. This page is for the 2004-2008 Acura TSX (Honda CL9), no others. Keep searching.
David Spalding - Ответить
I left decklid open overnight and now my instrument panel is not working
Anthony - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 44
За последние 7 дней: 313
За последние 30 дней: 1,469
За всё время: 304,661
