Введение
You'll probably never need to diagnose an instrument light problem with your car, but that doesn't mean you can't have fun performing this test. And knowing that the gauges and lights are working is reassuring.
If you want to show this to friends, be warned that HID headlights service life can be reduced by turning them on and off needlessly. The bulbs aren't cheap. I recommend pulling the fuses for them before doing this repeated.
This procedure is specific to HONDAs and ACURAs.
Выберете то, что вам нужно
This procedure involves turning on and off the headlights repeatedly, which which can reduce the HID headlights' mean lifetime before failure. As a precursor, consider removing the 15A left & right low headlight fuses from the under-hood fuse box, positions 1 and 6. (Refer to your Owners Manual for instructions, or an iFixit guide.)
Insert the ignition key into the ignition lock. Leave it in the 0 or I position.
Push and hold the Sel/Reset knob (on the instrument panel by the fuel gauge), or the Sel/reset button on the right hand of the steering wheel below the Multi-Information Display Info button.
Within five seconds, and still holding in the Sel/Reset button, turn the headlights OFF, then ON, then OFF again.
Within 5 seconds, release the Sel/reset button.
Push and release the Sel/reset button button 3 times repeatedly.
Each successive press of the Sel/reset button initiates a new cycling of all the gauges.
To end, turn the ignition switch to OFF, or vehicle speed exceeds 1.5 mph.
How do I relearn my cluster on my 05 chev verturr I did Mark the niddle
I didn't mark the needle before I took apart to put speedmotor how do I get it right
Wrong vehicle, dude. Hope you figured it out or got a friend to help out.
Can I do this to my 03 Chevy
15 участников успешно повторили данное руководство.
3 Комментариев
Folks, don’t post here asking about A COMPLETELY DIFFERENT VEHICLE. This page is for the 2004-2008 Acura TSX (Honda CL9), no others. Keep searching.
I have an 08 Acura TSX. The lights on the dash are flashing on and off. None of the guages work, neither does the heater. when I plug in my OBD, it throws a U0155 code, lost communication with the instrument panel cluster. The funny thing is, when I plug in the OBD, the instrument cluster work fine, as well as the heat. Please help!
