Введение
This guide shows how to replace the motherboard of your Insignia Flex 10.1 tablet.
Выберете то, что вам нужно
The rear panel is secured to the front case by 26 clips attached to the rear panel. These clips lock onto small tabs machined into the front case.
To free the tabs, they must be pushed toward the center of the device. When using the plastic opening tool to free the rear panel, be sure to work the tool at the location of these clips.
Remove back cover by inserting a plastic opening tool along the edge of the device to release the clips.
Opening the Flex 10.1 can be challenging. Don't get discouraged if it takes multiple attempts before the Flex 10.1 is opened.
Insert the plastic opening tool into the seam between the front case and the rear panel of the Flex 10.1.
Gently enlarge the existing gap by pressing and wiggling the plastic opening tool into the gap near each of the clips attached to the rear case, pushing the clips toward the center of the device until the clips have been freed.
Repeat the same procedure to free all clips around the Flex 10.1.
After ensuring all clips are free, separate the two halves of the Flex 10.1.
The rear panel is now free from the Flex 10.1.
With the rear panel removed, the back side of the Flex 10.1 should look like this.
Remove the ribbon cable by lifting up on the connection with a plastic opening tool and pulling out the ribbon cable.
Unsolder the 18 solder joints labeled in GREEN in the picture. Begin by heating up each solder joint on the motherboard.
When the solder melts and the wire is free from the motherboard, immediately lift the solder tip off the connection to avoid damage.
Use a Phillips head #0 screwdriver to unscrew the 5 philips head screws labeled in BLUE.
The motherboard is now free. Lift the motherboard with your hands or a plastic opening tool.
The motherboard can now be replaced.
2 человек успешно провели ремонт по этому руководству.
3 Комментарии к руководству
You're replacing the mother board, and yet you CUT all the wires coming into the motherboard. Now to put a new mother board on, you'll have replace the wires you cut. The proper thing would be to de-solder the wires off the motherboard, leaving them intact to reconnect to the new board.
your so right
Where can you get a new motherboard from .
