Введение
This guide will teach you to replace the battery in an Insignia Flex 10.1 NS-P10W8100. If you are experiencing other issues, please check out the troubleshooting page. Be careful when dealing with batteries as they can contain corroded material and potentially stored electricity.
Выберете то, что вам нужно
Carefully open the laptop and remove the keyboard by disconnecting it.
Place keyboard to the side as you will not need it.
Lay the screen flat on its surface and use the iFixit opening tool to remove the cover by gently prying the back cover from the screen.
Use your fingers and pry the back cover from the screen. You may need to wiggle the cover a bit to separate the pieces.
If the back cover does not come off, work your fingers around the corners and slowly pry the cover off using your fingers.
Unplug the power supply by disconnecting the red and blue wires found on the motherboard.
Lift up on the black locking flap, being careful not to damage the surrounding hardware parts.
Remove the ZIF ribbon wire by pulling horizontally towards the battery.
Remove the black tape from the small ribbon wire connector.
Pull the ribbon connector out of the plug the same way that was mentioned in step 4.
Еще один человек закончил это руководство.
2 Комментариев
Very concise and helpful. Thank you
where can i buy the replacement battery?
