Введение
Although there are no known hazards with removing the camera, be careful not to damage any small components or permanently damage any connectors.
Выберете то, что вам нужно
Carefully open the laptop and remove the keyboard by disconnecting it.
Place keyboard to the side as you will not need it.
Lay the screen flat on its surface and use the iFixit opening tool to remove the cover by gently prying the back cover from the screen.
Use your fingers and pry the back cover from the screen. You may need to wiggle the cover a bit to separate the pieces.
If the back cover does not come off work your fingers around the corners and slowly pry the cover off using your fingers.
Carefully remove the yellow tape holding down the camera ribbon connector by pulling it upwards.
Remove the black tape holding down the camera ribbon connector which is attached to the motherboard.
Disconnect the zero insertion force (ZIF) connector by using your fingernail to flip the small locking flap.
Disconnect the cable by gently pulling it outward.
Еще один человек закончил это руководство.
