Введение
This guide will show you how to replace the camera on your Insignia Flex 10.1 tablet.
Выберете то, что вам нужно
Use a plastic opening tool to remove the rear panel from the front case.
Insert the plastic opening tool between the front case and rear panel. Use a prying motion to lift the front case from the rear panel.
Use a plastic opening tool to flip up the ribbon connector that connects the camera to the motherboard.
Free the ribbon cable from the motherboard.
Use a #00 Phillips head screw driver to remove the two screws that hold the camera down to the front case.
