Введение
This guide will show you how to replace the camera on your Insignia Flex 10.1 tablet.
Выберете то, что вам нужно
Use a plastic opening tool to remove the rear panel from the front case.
Insert the plastic opening tool between the front case and rear panel. Use a prying motion to lift the front case from the rear panel.
Use a plastic opening tool to flip up the ribbon connector that connects the camera to the motherboard.
Free the ribbon cable from the motherboard.
Use a #00 Phillips head screw driver to remove the two screws that hold the camera down to the front case.
Use tweezers or your fingers to remove the camera from your Insignia Flex 10.1 NS-P16AT10.
