Выберете то, что вам нужно
Insert a plastic opening tool into the seam between the back casing and the screen to separate the back casing from the tablet.
Lift the back casing away from the rest of the device which should include the exposed circuit board and screen.
Set the casing aside.
Use a plastic opening tool to flip up the black strip that is holding the orange camera ribbon near the module on the circuit board labeled "front camera" in white print.
Repeat this action on the orange camera ribbon near the module on the circuit board labeled "back camera" in white print.
Peel off the grey tape covering the ribbons, in order to separate the cameras and their respective ribbons from the rest of the device.
Use a a plastic opening tool to pry out the back camera at the top of the circuit board.
