Введение
Tablet screens often need replacement. This guide will assist you in a full screen replacement for the Insignia Flex 8 NS-P08A7100 resolving a screen that is cracked, not responding to touch, or not showing anything while powered on.
Warning: Before you begin, discharge your Insignia Flex 8 NS-P08A7100 battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
Выберете то, что вам нужно
Begin by using the opening tool to pry open the back cover. Continue around the edge until the back cover pops off.
Use the opening tool to flip the LCD flex circuit plug upwards. The flex circuit should now be loose. Remove flex circuit by pulling outwards.
Pry the battery from the back of the LCD screen using the opening tool. Due to the strong adhesive between the battery and screen, this may take some time.
Begin removing the screws on the circuit board using the phillips-head bit driver. Start with the top left corner.
Remove the next screw to the right using the phillips-head bit driver. This one is slightly hidden under the flex circuit of the camera.
Remove the next screw in the right top right using the phillips-head bit driver.
Remove the next screw in the bottomeright corner using the phillips-head bit driver.
Remove the next screw in the bottom left corner using the phillips-head bit driver.
Remove the flex circuit on the left side of the circuit board using the opening tool.
Flip the camera flex circuit clip upwards using the opening tool. Detach the camera flex circuit from the circuit board
Remove the adhesive tape holding the circuit board to the LCD screen. The circuit should now be free.
Pull the circuit board forward for clearance and begin removing the screen with the opening tool.
