Введение
This replacement guide will help you to remove and replace the cameras in your Insignia Flex 8 tablet. If your front or back-facing cameras are not working, or the photos are blurry, replacing the camera(s) may be the best way to fix this problem.
Выберете то, что вам нужно
Wedge the plastic opening tool anywhere in the seam between the back casing and screen.
Slide the plastic opening tool along the sides and corners of the seam of the device while it separates from the screen.
Gently peel all of the tape that is covering the cable connections going to and from the cameras. Set the tape aside for later reassembly.
Locate camera ribbon connector.
Using finger flip up black flap of camera ribbon connector.
Using metal spudger tool, gently pry right speaker away from adhesive.
Move right speaker to left side of device so you can freely access the camera ribbon.
Lift up connector ribbon that is attached to the cameras.
Slide cameras and connector ribbon out from underneath the speaker cords and battery.
