Insignia Flex 8 NS-P16AT08 Speakers Replacement
Выберете то, что вам нужно
  1. Insignia Flex 8 NS-P16AT08 Speakers Replacement, Back Casing: шаг 1, изображение 1 из 3 Insignia Flex 8 NS-P16AT08 Speakers Replacement, Back Casing: шаг 1, изображение 2 из 3 Insignia Flex 8 NS-P16AT08 Speakers Replacement, Back Casing: шаг 1, изображение 3 из 3
    • Make sure device is powered off.
    • Wedge the plastic opening tool anywhere in the seam between the back casing and screen.
    • Slide the plastic opening tool along the sides and corners of the seam of the device while it separates from the screen.
    • You will hear the popping sound of the plastic connections separating from the device.
  2. Insignia Flex 8 NS-P16AT08 Speakers Replacement: шаг 2, изображение 1 из 1
    • Lift the back casing away from the screen.
    • Set casing aside.
  3. Insignia Flex 8 NS-P16AT08 Speakers Replacement, Speakers: шаг 3, изображение 1 из 2 Insignia Flex 8 NS-P16AT08 Speakers Replacement, Speakers: шаг 3, изображение 2 из 2
    • There are two connections that attach the speakers to the motherboard.
    • Unplug the cables from the motherboard by gently pulling them away.
    • Speaker cables will be free to be removed.
  4. Insignia Flex 8 NS-P16AT08 Speakers Replacement: шаг 4, изображение 1 из 2 Insignia Flex 8 NS-P16AT08 Speakers Replacement: шаг 4, изображение 2 из 2
    • Remove the tape that is holding the speaker cables down.
    • Remove the speaker cables from underneath the black connector ribbons.
    • The cables are hooked underneath black connector ribbons; carefully unhook them.
  5. Insignia Flex 8 NS-P16AT08 Speakers Replacement: шаг 5, изображение 1 из 1
    • Gently pry both speakers away from adhesive with metal spudger tool.
    • Always use a nylon spudger or plastic opening tool before a metal spudger. Metal spudgers are great for serious prying power but can damage your device if used incorrectly.
    • The speakers can now be completely removed from the device.
Заключение
Jose Diaz
Участник с: 04/03/16
20 Репутация
1 руководство автора
Команда
Eastern Washington University, Team 2-1, Andersen Spring 2016 Участник Eastern Washington University, Team 2-1, Andersen Spring 2016
EWU-ANDERSEN-S16S2G1
5 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 6
За последние 30 дней: 9
За всё время: 217
