Введение
This guide will enable the user remove and replace the main camera of the tablet.
Выберете то, что вам нужно
Use a plastic opening tool to remove the metal backing of the tablet.
Insert the plastic opening tool between the screen and metal backing. Use a prying motion to lift the front case from the metal panel.
Move the tool around the perimeter of the device until the screen separates.
Once the the tablet is open, locate the camera.
There is a small black ribbon connector which connects the camera to the motherboard.
Use a plastic opening tool to pry slightly on the black ribbon connector.
Bend the black ribbon connector slightly so it will not be in the way.
Using a plastic opening tool, pry the camera from the mount.
Pry around the perimeter of the camera until it comes free.
