Введение
This guide will have step-by-step instructions enabling the user have the ability to remove and replace the front camera of the Insignia Flex Elite 7.85.
Выберете то, что вам нужно
Use a plastic opening tool to remove the metal backing of the tablet
Insert the plastic opening tool between the screen and metal backing. use a prying motion to lift the front case from the the metal panel.
move the tool around the perimeter of the device until the screen separates.
once the tablet is open, locate the camera
The camera is fitted in a small square compartment
Use a plastic opening tool to pry slightly on the back of the camera making it easier to come out of its compartment
When removing the camera, ensure that the red and black wire on top of it is not disconnected from the motherboard.
Using a plastic opening tool, pry the camera from the compartment.
Pry around the perimeter of the camera until it comes out free.
Be careful, make sure the motherboard does not break.
The front camera should be out of its compartment by now. Reinstall the new camera.
