Введение
This guide provides instructions on how to replace the speakers in your Insignia Flex Elite 7.85.
Выберете то, что вам нужно
Use a plastic opening tool to remove the metal backing of the tablet.
Insert the plastic opening tool between the screen and metal backing. Use a prying motion to lift the front case from the metal panel.
Move the tool around the perimeter of the device until the screen separates from the back panel.
Use a plastic opening tool to free the orange connector ribbon by placing the tool on the connector.
Peal the connector ribbon and bend it backwards so it is not in the way.
Use the plastic opening tool to remove the battery from the screen.
Place the tool between the battery and casing. Move the tool around the border of the battery until it is free.
Take the battery out carefully from the tablet.
Take out the four screws circled in the second picture with the #000 Phillips screwdriver.
Place the speakers on the side.
Trim the wires with a wire cutter to solder the new speakers in place.
