Введение
This guide will show the steps required to disassemble an Insignia Ice Maker and replace the fan inside. It should take approximately 5-10 minutes.
Выберете то, что вам нужно
Locate the fan on the side of the Ice maker and undo the 4 screws holding it in place.
Remove the cover from the circuit board by pressing against the lever to the side. A pry tool may be needed.
Follow the fan's power cable and unplug.
You may have to cut a zip tie holding the cable in place.
Еще один человек закончил это руководство.
