Введение
The antenna is a very important component for the radio of the Insignia NS-B2110. Antennas may snap or break, causing the radio to stop working. Removing the antenna is a fairly easy and quick fix.
Выберете то, что вам нужно
On the backside of the device, lift the plastic handle up with your hands to reveal the antenna.
Lift the antenna to its upright position.
Remove one 6.0 mm Phillips #00 screw from the base of the antenna.
Remove the antenna from the metal bracket.
