Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
When the remaining batteries lose power, or die, you will need to replace them with new ones for your device to work. This guide will show you how to easily keep your device working.
Выберете то, что вам нужно
Flip the stereo so the CD opening is face down.
With two fingers, pinch the tabs and lift up to open the battery protection cover.
Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
Repeat until all eight batteries are removed.
