Выберете то, что вам нужно
Turn the boombox around to see the back, and then flip it upside down.
Insert a 2.5mm flathead driver into the two holes next to the battery compartment.
Turn the driver counterclockwise several times to loosen and pull out the 17mm screw.
Peel off the two black square foams in front of the battery compartment to reveal a screw under each one.
Remove the two 8mm screws using a 2.5mm flathead driver.
The front grey panel will loosen up once the final screw is removed.
Turn the boombox on its back.
Release the front panel by pushing down on the latches holding the panels together.
There are four silver latches on the top side of the panel and one on the bottom.
Turn the boombox around to view the back and lift the handle up.
Using the same driver with 2.5mm flathead, remove the two 14mm screws under the handle.
Gently lift the black top but do not pull completely away.
Start by unplugging the red and black cable connected to the motherboard
Unplug the red and pink wires connecting the top of the device to the motherboard
Disconnect the black shiny tape connecting the motherboard to the front of the device
Also disconnect the pink and white wires connecting the cassette unit to the device.
After disconnecting all the wires, the front panel is now free and easy to work on.
Инструмент, используемый на этом этапе:Flathead 3/32" or 2.5 mm Screwdriver$5.49
To remove the cassette unit, use a 2.5mm flathead on the 4 screws holding the unit together.
While pressing the eject bottom, pull the cassette unit down and away from the front panel.
