Введение
This guide shows you how to replace a broken display on the Insignia NS-CLIP02. The device should be physically unplugged, not just “switched off.” If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
Выберете то, что вам нужно
Set the clock radio on the work space so the bottom of the device is showing.
Use a metal spudger to peel back the adhesive sticker on the bottom of the clock.
Use a Phillips screwdriver to remove the six 11 mm screws on the bottom of the device.
Use a Phillips screwdriver to remove the 9.5 mm screw located near the center of the motherboard.
Using the Phillips screwdriver, remove the three screws that run along the center of the base.
Once the face plate is removed, use the Phillips screwdriver to remove the six screws shown here.
