Введение
This guide shows how to locate and repair broken connections to the speakers.
Выберете то, что вам нужно
Set the clock radio on the work space so the bottom of the device is showing.
Use a metal spudger to peel back the adhesive sticker on the bottom of the clock.
Use a Phillips screwdriver to remove the six 11 mm screws on the bottom of the device.
Use a Phillips screwdriver to remove the 9.5 mm screw located near the center of the motherboard.
You can see that there are several points where connections to the speaker are soldered.
