Введение
Outline what you are going to teach someone how to do.
Выберете то, что вам нужно
Turn the clock over and remove the 1cm screw with a Philips head screwdriver, which is located below the faceplate, on the bottom of the clock.
Once you are able to create a space in between the device and the front screen, use your hands to continue to pry off the screen. Make sure that all the mini latches surrounding the perimeter have been unlatched, allowing the screen to come off easily.
Once you have undone the latches and pried off the first half of the screen, use your hand to pull off the rest of the screen.
2 участников успешно повторили данное руководство.
