Введение
An Insignia NS-CLOPP2 Speaker is used to wake one up with a clear alarm for waking up on time as well as a built-in radio tuner for listening entertainment. Here are the tools, skills, and requirements needed to replace a broken Insignia NS-CLOPP2 Speaker that is no longer creating any type of noise or the speaker is creating gray noise.
Выберете то, что вам нужно
First, unscrew the back panel with a 1/3 Phillips screwdriver, and make sure the motherboard has been pulled out, not cutting any of the wires attached, exposing the blue speaker.
Locate the speaker, the dark blue colored circular device, pictured in the center of the photo.
Using a plastic opening tool, scrape off the glue attaching the speaker to the black plastic of the clock.
Lastly, once the adhesive has been removed, gently lift the speaker out of place.
To put a replacement speaker in, use technology-friendly adhesive to glue it back in place.
Еще один человек закончил это руководство.
