Введение
The Insignia NS-D160A14 A/V board has the A/V jacks built in. Reasons to replace this part might include the DVD player not displaying correctly on your television or a no audio error. This guide will show the user how to disassemble the DVD player, disconnect the A/V board, and then remove the A/V board.
Выберете то, что вам нужно
Remove the two 7mm Phillips #2 screws from the back of the DVD player.
Unhook the 4 hooks on the main casing.
There is one hook on the top of the casing, one on the bottom, and one on each side.
Keeping the 8-pin connector as straight as possible, lift the motherboard out of case.
Remove the two white cables connected to the A/V board from the optical drive using your fingers.
Lift the A/V board upwards until you feel it come free from the indentations in the housing.
Gently push on the A/V jacks with your thumb from the outside as you lift the board out.
