Введение
This guide will teach you how to remove the optical drive from the Insignia NS-D160A14 in case it is damaged.
The optical drive will be connected to the AV board via white cables. You will need to remove the case and front plate of the DVD player to remove the drive from the DVD player.
Lets get started!
Выберете то, что вам нужно
Remove the two 7mm Phillips #2 screws from the back of the DVD player.
Unhook the 4 hooks on the main casing.
There is one hook on the top of the casing, one on the bottom, and one on each side.
Keeping the 8-pin connector as straight as possible, lift the motherboard out of case.
Disconnect the white cables connected to the optical drive from the A/V board using your fingers.
After removing the white wires connected to the A/V board, the optical drive should slide out of the slot.
