Введение
This guide shows how to replace the screen for the Insignia NS-DS9PDVD15.
Выберете то, что вам нужно
After the back is removed and the disk tray is loose from the bottom, locate the two, 3 mm screws that hold the tray to the hinge.
Unscrew them with the JIS #000 screwdriver.
After the bottom cover and disk tray have been removed, remove the back panel from the top half.
There are six, 9 mm screws on the bottom cover and 2 screws on the hinge. Remove them with the JIS #000 screwdriver.
Remove the ribbon cable carefully with the pry tool.
First, push out the black portion.
Unscrew the corners of screen with the JIS #000 screwdriver. There are four, 6 mm screws with washers.
After the screws and washers are removed, you can lift the screen off with the pry tool.
