Введение
This guide shows how to replace the speakers on the Insignia NS-DS9PDVD15.
Выберете то, что вам нужно
After the back is removed and the disk tray is loose from the bottom, locate the two, 3 mm screws that hold the tray to the hinge.
Unscrew them with the JIS #000 screwdriver.
After the bottom cover and disk tray have been removed, remove the back panel from the top half.
There are six, 9mm screws on the bottom cover and 2 screws on the hinge. Remove them with the JIS #000 screwdriver.
Remove the ribbon cable carefully with the pry tool.
First, push out the black portion.
After the ribbon cable is removed, unscrew the eight, 9 mm screws from the PC board
Flip over the PC board. Remove the two sets of red and black wires which connect to the speakers.
Use the pry tool at the white clip, to remove the wires. Then you can remove the speakers.
