Введение
The oscillation gear swivels the head of the fan back and forth by translating power from the motor into the oscillation arm.
Выберете то, что вам нужно
Unplug your fan.
Remove the 20 mm bolt that fastens the fan ring located at the bottom of the fan cage with a Phillips #3 screwdriver.
Remove the 8 mm bolt fastening the fan blades to the rotor with a Phillip #3 screwdriver.
Unscrew the four 8 mm bolts that fasten the back of the fan cage back to the motor housing with a Phillips #3 screwdriver.
Unscrew the 10 mm screw in the center hole of the oscillation knob with a Phillips #3 screwdriver.
Use your fingers to gently pull the power knob directly away from the motor housing.
Unscrew the flat 17 mm nut fastened at the bottom of the power knob with a small crescent wrench.
Remove the four 6 mm bolts and small washers that secure the front face of the motor housing with a Phillips #3 screwdriver and remove the washers.
Using a Phillips #3 screwdriver, unscrew and remove the 7 mm long bolt and small washer fastening the yellow and green wire to the motor housing support.
Using a Phillips #3 screwdriver unscrew the 13 mm long screw fastening the motor housing support to the oscillation gear box.
Using a Phillips #3 screwdriver, unscrew the three 13 mm long screws fastening the grey plate to the top of the oscillation gear box.
Remove the grey cap covering the oscillation gear box.
Еще один человек закончил это руководство.
