Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the rubber screw caps using the pointed tip of the Spudger.
Remove the four 6.0 mm Phillips screws located below the rubber caps using the PH00 bit installed in the driver.
Use the plastic opening tool to pry open the back cover.
Slide the tool around the sides of the radio to gradually pry the back cover off. Do not remove the cover completely as there is still a cable connecting it to radio.
Use the blunt tweezers to unplug the battery cable from the PCB board. Grab the battery cable plug from the sides.
Use the flat side of the Spudger to pry the battery out of the back cover.
Insert the replacement battery into the back cover.
Reassemble the radio, making sure to reconnect the battery cable.
2 участников успешно повторили данное руководство.
