Введение
The Insignia 2-in-1 Handheld/Stick vacuum, over time, will lose its ability to work for extended amounts of time. Use this guide to access the battery for replacement and troubleshooting.
Выберете то, что вам нужно
Push down the black button to release the dust cup.
Pull the dust cup up and away from handheld portion to remove.
Remove the five 12.0 mm screws on the back of the handheld portion using the Phillips #2 screwdriver.
Lift the silver cover off of the black body of the handheld portion to expose the battery and wiring.
Pull apart the red and black wires.
Do so for all of the wires. (Red x1, Black x2)
Remove the tape holding the battery to the black housing.
Slide the entire battery bundle out.
Еще один человек закончил это руководство.
