Введение
Does your device not turn on or does the power run out quickly? It is probably the result of a dysfunctional battery. This guide will show you how to remove your battery for a replacement. Be aware that this guide has some steps that can possibly damage the device.
Выберете то, что вам нужно
Detach the back cover by carefully pulling up and out on the back plastic casing.
Use the plastic opening tool to reach underneath the battery, opposite from the side with the red wire, and remove it from its plastic case.
Reach under the white plastic wire connector using the plastic opening tool and disconnect it from the socket.
Еще один человек закончил это руководство.
