Inspiron 17 5758 Hard Drive Replacement
Выберете то, что вам нужно
  1. Inspiron 17 5758 Hard Drive Replacement, Remove battery: шаг 1, изображение 1 из 1
    • Flip the laptop over, battery facing you. Move the latch to the right, and grab the battery as it comes up.
  2. Inspiron 17 5758 Hard Drive Replacement, Remove hard drive cover: шаг 2, изображение 1 из 1
    • Remove the two Philips screws securing the hard drive cover.
    • Use a spudger in the provided hole to pry the cover upwards.
  3. Inspiron 17 5758 Hard Drive Replacement, Remove hard drive caddy: шаг 3, изображение 1 из 1
    • Remove the four Philips screws securing the hard drive caddy.
    • Remove the four screws from the hard drive caddy, and take the SATA connector off. You're done!
    Please include instructions on the Interposer Connector and cable…how to unplug and how to reattach before closing the back of the computer. The computer won’t recognize the hard drive unless this is reattached, and it is very flimsy.
    Thank you.
    James Bort - Ответить
Заключение
Еще один человек закончил это руководство.
Joseph Sctbunio
Участник с: 09/23/17
7 554 Репутация
Автор 42 руководств
1Комментарий к руководству
I found it very straightforward to purchase a Kingston KC600 SSD drive, which includes an external caddy, then use the free Aomei cloning software to clone the existing drive, then follow this article to open up the Inspiron, remove the SATA drive and install the KC600 drive instead. Thanks! It had become unbearable slow running Windows 10 but now has another lease of life.
Imogen - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 5
За всё время: 818
