Введение
This guide will follow you though to replace the HDD.
Выберете то, что вам нужно
Turn the laptop upside down with the logo facing the surface of the table.
Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
Unscrew three 3mm screws with a Phillips #0 screwdriver and remove them.
These screws hold the hdd and removing these screws will make it easier to remove it.
Lift the hard drive from the left side. Be careful not pull on it.
Pull the SATA cable that's connect to the hard drive and then carefully place the cable on the side.
Еще один человек закончил это руководство.
