Введение
If you've got a luxury car like an Audi A5, you'd probably want full-on LED lights to complement that luxury car. This is a easy way to change out your stock license plate lights into some fresh looking LED bulbs.
Выберете то, что вам нужно
Get a Philips screwdriver and remove the screws from the license plate lamps.
Directly replace it with the new Error Free LED bulb.
Remember to have the LED emitter facing outwards, towards the license plate lens.
Put the license plate lamp back and screw in the assembly.
Repeat on the other side.
Installing this LED license plate bulb is extremely easy and straightforward. Make sure to test everything to see if it works.
5 участников успешно повторили данное руководство.
Один комментарий
Please consider that LED replacement bulbs like the linked one usually are not labelled with the mark of conformity and therefore not legal within the EU. For some cars legal LED replacements are available as original spare parts from the car manufacturer.
