Введение
Hate the look of halogen bulbs? Get rid of the dull yellow with a new set of LED license plate lights. Installation is very easy and will only take you a few minutes.
Инструменты
Запчасти
Детали не указаны.
  1. Install LED License Plate Lights, license plate lights: step 1, image 1 of 2 Install LED License Plate Lights, license plate lights: step 1, image 2 of 2
    • Take a flat head screwdriver and remove the license plate housing cover.
  2. Install LED License Plate Lights: step 2, image 1 of 1
    • Remove the bulb housing.
  3. Install LED License Plate Lights: step 3, image 1 of 2 Install LED License Plate Lights: step 3, image 2 of 2
    • Remove the stock license plate bulb.
  4. Install LED License Plate Lights: step 4, image 1 of 2 Install LED License Plate Lights: step 4, image 2 of 2
    • Directly replace with the new LED license plate bulb. If it doesn't light up, flip the LED bulb 180 degrees.
  5. Install LED License Plate Lights: step 5, image 1 of 3 Install LED License Plate Lights: step 5, image 2 of 3 Install LED License Plate Lights: step 5, image 3 of 3
    • Put everything back the same way it was removed.
Заключение
You can see from these instructions that installation was very easy. Enjoy your new LED license plate lights.
7 участников успешно повторили данное руководство.
Eric Wu
Участник с: 21.01.2015
3 237 Репутация
Автор 23 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 10
За последние 30 дней: 49
За всё время: 1,747
