Install firmware on Xbox One S
Выберете то, что вам нужно
  1. Install firmware on Xbox One S, Warning: шаг 1, изображение 1 из 1
    • Before doing any updates or software changes with the Hard Drive connected to the motherboard, make sure that all connections to the board are secure, such as the disc drive, otherwise you will brick the Motherboard, and will require a new one.
  2. Install firmware on Xbox One S, Prerequisites: шаг 2, изображение 1 из 1
    • Before beginning this guide, it is best to read through the steps for the hardware portion, as shown by iFixit user Andrew, at the following link.
    • Xbox One S Hard Drive Replacement
    • You will also need a PC running Windows, and a hard drive reader (Sata Data and Sata Power to USB)
    • Seagate drives have been known to cause issues with Xbox One software.
  3. Install firmware on Xbox One S, Connect Your New HDD: шаг 3, изображение 1 из 1
    • Connect the new hard drive to the PC. Make sure that the HDD is in a location where it will not be accidentally disconnected.
  4. Install firmware on Xbox One S, Download the Script: шаг 4, изображение 1 из 1
  5. Install firmware on Xbox One S, Open Command Prompt as Admin: шаг 5, изображение 1 из 1
    • Press the Windows key/Start menu and type in "CMD", right click, and select 'Run as Administrator"
    • Type the command "cd C:\Users\(Your Name)\Downloads\xboxonehdd-master-6.1\xboxonehdd-master\win"
    • Replace (Your name) with the name of your user profile.
  6. Install firmware on Xbox One S, Run the Batch File: шаг 6, изображение 1 из 1
    • Run the command "create_xbox_drive"
    • The next steps are to create a drive that has either 500GB, 1TB, or 2TB storage. If at anytime you get confused, there is a readme file in the folder you extracted that can help out as well.
  7. Install firmware on Xbox One S, Follow the On Screen Instructions: шаг 7, изображение 1 из 2 Install firmware on Xbox One S, Follow the On Screen Instructions: шаг 7, изображение 2 из 2
    • For this tutorial, we are using the first option (a) Replace/Upgrade w/o a working original drive.
  8. Install firmware on Xbox One S, Follow (continued): шаг 8, изображение 1 из 3 Install firmware on Xbox One S, Follow (continued): шаг 8, изображение 2 из 3 Install firmware on Xbox One S, Follow (continued): шаг 8, изображение 3 из 3
    • Make sure to choose the right drive to format, Disk 0 is almost always your operating system, DO NOT CHOOSE DISK 0.
    • It will ask you to confirm your selection.
    • Then you will need to choose the size of the drive you have created.
  9. Install firmware on Xbox One S, The Command is Complete.: шаг 9, изображение 1 из 1
    • Once the command line displays 6 lines of long numbers with "GUID" at the top, the command lines is finished.
    • If this doesn't work, clean the disk with diskpart, link below, and try again.
    • http://knowledge.seagate.com/articles/en...
  10. Install firmware on Xbox One S, Download the Firmware: шаг 10, изображение 1 из 3 Install firmware on Xbox One S, Download the Firmware: шаг 10, изображение 2 из 3 Install firmware on Xbox One S, Download the Firmware: шаг 10, изображение 3 из 3
    • You need to go to the XBox official site and download a file called OSU 1.
    • https://support.xbox.com/en-US/xbox-one/...
    • Select "I need to update my console offline"
    • Select "Xbox One S or Xbox One X"
    • Click the green link "OSU1" to start the download.
  11. Install firmware on Xbox One S, Copy files: шаг 11, изображение 1 из 3 Install firmware on Xbox One S, Copy files: шаг 11, изображение 2 из 3 Install firmware on Xbox One S, Copy files: шаг 11, изображение 3 из 3
    • Navigate to the System Update (X) drive, and create 2 folders, one labeled "A" and one "B"
    • Extract all of the files from OSU1, and copy everything in $SystemUpdate, except for "updater.xvd"
    • Paste these files in the folders "A" and "B" that you created.
    • Copy "updater.xvd" from $SystemUpdate and paste it in the root of System Update (X)
    • Note that you will need to download the bootanim.dat and store it in folders "A" and "B" as well. There are two different versions you can download one for OG / S or the X. Without the file the Xbox will boot with a black screen to the menu and not the boot logo.
  12. Install firmware on Xbox One S, Put the Hard Drive in the XBox: шаг 12, изображение 1 из 1
  13. Install firmware on Xbox One S, Reset console: шаг 13, изображение 1 из 1
    • Some users have experienced sign in issues after an ssd upgrade. If this occurs, simply reset the console (keep games and apps if need be.) and that should resolve the issue.
    • Those who have their Xbox set to "energy saving" mode for startup may experience a 20-30 second black screen before boot. Changing this setting to "instant on" resolves this issue.
    • Now enjoy 20x faster r/w speeds and loading times a fraction that of a standard HDD.
  14. Install firmware on Xbox One S, You are Finished: шаг 14, изображение 1 из 1
    • You are now finished, enjoy your XBox!
    • Note: This does work with Solid State Drives.
Заключение
To reassemble your device, put the hard drive back in the Xbox One S and reassemble.
44 человек успешно провели ремонт по этому руководству.
KimJongIan
Участник с: 04/27/18
1 541 Репутация
1 руководство автора
48 Комментарии к руководству
It doesn’t work for me. Always “No USB/SATA drives found”. All drives are “online”.
Dennis Becker - Ответить
I have the same problem, I can’t decide what to do?
Диск ### Состояние Размер Свободно Дин GPT
Диск 0 В сети 1863 Gбайт 0 байт
Диск 1 В сети 3726 Gбайт 0 байт *
Диск 2 В сети 1863 Gбайт 0 байт
Диск 3 В сети 1863 Gбайт 1863 Gбайт
Диск 4 В сети 223 Gбайт 2048 Kбайт
Диск 5 Нет носителя 0 байт 0 байт
* No USB/SATA drives found *
* Script execution complete.
eshkinin.s -
Works perfect, back up and running… thanks!
dvmath50 - Ответить
Doesn't work with soild state drives? Isn't that what's in there to begin with?
Rob Hartwig - Ответить
This does work with solid state drives, it doesn’t work, occasionally, with seagate drives.
KimJongIan -
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 56
За последние 7 дней: 387
За последние 30 дней: 1,986
За всё время: 230,218
