Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive
Выберете то, что вам нужно
  1. Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive, Lower Case: шаг 1, изображение 1 из 1
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
    Step 1 (technically step 9 - replacing the base plate) Apparently one of my screws was a micron or two smaller than the others. This screw belongs to the hole above the optical drive, which is also apparently a couple of microns smaller than the others. It took seven attempts to figure which screw had originally been in that hole; all the other screws were too large, but fitted perfectly everywhere else.
    Bizarre much?
    Will - Ответить
    It might be a matter of how the screws are driven in, and not that they're slightly different sizes. When I reassembled my MacBook, a couple of the screws, including the one over the optical drive you mention, were hard to drive in and jutted up a little bit instead of sitting entirely flush. Swapping screws didn't help. The solution was to unscrew them and drive them in at a bit of an angle - perpendicular to the slightly curved surface of the back plate where the screw holes were, instead of fully vertical with respect to the ground the Macbook is sitting on. Doing it that way, the screws were easier to drive in and they all ended up flush in their holes. Didn't matter which screws they were. (I swapped a few around just to check after reading this.)
    Andrew Janke -
    I had no such screw issues. Either there are differences in manufacturing lots or I just got incredibly lucky during reassembly!
    xtophr -
    I discovered a great way of organizing the screws. I used an ice cube tray and added the screws in order, keeping the different kinds together. So when it came to reversing the steps, the screw order was an added control step to returning everything in its place.
    leonie - Ответить
    Great advise! Love it! :)
    Ririds -
    I used to do that and that worked really great until I bumped it by accident and the entire tray went on the rug! I spent the next day sorting things out.
    Now I use these:
    http://www.sciplus.com/p/50-114-CLEAR-PL...
    The lower ones 50 to a package. I mark them w/ blue tape. Often if it's part like the fans, or the optical drive I'll tape the screws into/near the holes where they belong. I did this a lot especially w/ the bottom screws from MBPs until I'd done so many I knew exactly where the longer ones went.
    Richard Sato -
    I wrapped the screws in a piece of blue masking tape and wrote the number on the little pouch I made. Then I stuck the blue tape pouches on the underside of the case bottom in order.
    Roscoe -
    I take double-sided tape, put that on a piece of paper, stick the crews to that, and label them.
    jelimoore -
    Best I've found is a bead sorting tray. They're like $5 at Wal-Mart and they have a lid that seals up and won't let them jump between containers.
    maccentric -
    I take a sheet of paper, pierce the screws through the paper, take a pen and box the screws and write out what step they belong to.
    Nils -
    @Will, in my case I had the same result as you did. As a reminder to myself the next time I need to open the computer, I put a dot of white paint on those two screw's head and a very, very thin ring of white on the very edge of each hole, that way I'll know they go into those two holes.
    Roger - Ответить
    Actually the four screws on the bottom were not threaded all the way up. I didn't check to see if the thread gauge was the same on them, but it wasn't until I had about four screws out (I didn't take them out in the order that the bottom all came out first) that I noticed a difference. I then took out the rest of the bottom ones to see if they matched the two that were already out that weren't threaded to the top. They did. So I went under the assumption that those were all bottom screws and when I put it back together everything went fine with no resistance.
    So there are three types of screws: Four for the bottom, three long ones as indicated and three others that might be slightly smaller than the bottom ones.
    wresnick - Ответить
    Hi,
    Although its more than a year since your contribution, I thought you might be amused to know that it is not just that the screws go in more easily when at an angle, Apple actually drilled and tapped the holes at a 15% angle. I too had tried to drive them in straight. An Apple "genius" - I was in for something else - clarified the design for me. It was done so that the screws lay flush on the angled part of the lower case. Nice design, but since Apple encourages DIY memory and drive changes, they could have mentioned this little ... trap.
    H Stahl -
    MacBookPro8,2
    Intel Core i7, 2,2 GHz, RAM 16 GB
    Mountain Lion
    May someone help me?
    I have installed the second drive with ssd 840 evo, but when I try to copy the file from the new drive to the main hd this in not allowed (errore -36)
    Piero - Ответить
    To my knowledge you can't transfer a single file more than 4gb. I advise compressing to a bunch of rars to split the file size and moving them individually
    1982sketcher -
    Hey everyone, here's the very best way to PERFECTLY organize your screws AND keep track of the order of the procedure: Get a piece of plain corrugated cardboard and a pen (I like using a Sharpie). For EACH step of the disassembly, draw a simple diagram of the layout of the computer on the piece of cardboard, with dots or Xs where the screws are located. Right after you remove each screw from the computer, poke a hole in the cardboard in its corresponding diagram position with your screwdriver and place the screw in that hole. If there are other non-screw related parts to be removed, you can add notes below each step diagram to remind you of where they go or how they should be placed. This cardboard method is great not only because your screws will not go flying or get mixed up by accident if bumped, but each screw goes EXACTLY back where it came from and you can keep the cardboard as a template for future use if necessary!
    - zerø K
    zeroK - Ответить
    These instructions worked great for me. I ordered a replacement battery from Key Power (on Amazon) for my 15" Macbook Pro (mid-2010). Cost was $74 shipped.
    Battery came with 3 different screwdrivers to help with installation. I just needed the one size though, since my 2010 seemed to use all the same size screws.
    Thanks!
    Marcos - Ответить
    During re-assembling (put the screws back in), it is important to note that the 3mm threaded holes are not completely vertical, but bent a little bit such that the hole direction is rectangular to the tapered surface. The force of the screwdriver must point towards the direction of the hole. Otherwise the screw gets jammed
    kusi - Ответить
    There is a FOOLPROOF WAY TO ORGANIZE ALL SCREWS and other parts removed.
    Print the repair guide.
    Yes, the actual photo of the bottom of the laptop with the circles around the screws.
    When you remove the screw, tape it to the photograph.
    You will tape the screw to the exact location that you just removed it from.
    Same thing with any part you remove.
    splashzoneent - Ответить
    Thanks Splash!!! I used your suggested method, and it was perfect: kept all my screws, and i was able to, very easily, put them back in their correct place. I greatly appreciated your feedback. Thank you for sharing!!
    Tommy Kedar -
    Thank you!!! This worked fabulously - even the I.T. people at my workplace were excited as they never thought to do that before. Replacing the battery took about 10 minutes!
    nclarke36 -
    Worked like a charm! Took less than 20 minutes.
    It's Oct. 2015, and the fan cost me about $10. it was the same brand/model...
    SUNON MG62090V1-Q020-S99 .
    SOME TRICKS -
    1- no T6 screwdriver- was careful using needle nose players to loosen 2 screws protruding up, then use a small phillips to push real hard into the T6 slots, SLOWLY turn , also used a small flat head screwdriver (for eye glass repair) was able to grab thread on T6's, made a small mark with screw driver across the top so I could see when it started to turn.
    2- no spudger -made one; cut a little strip 1/2" x 1 1/2" of plastic. couldn't get it to slide under plug, there's an edge where plug fits. so lifted old fan out, pulled upward on the plug it popped right out with very little effort. I used my home made spudger to push the new plug into place.
    3- download free "Macs Fan Control" This is how I was alerted to the fan not working in the first place. Program shows temperature of all key components in the computer.
    cheers- Durango CO!
    Dgodrummer - Ответить
    Watch the video first, read the entire tutorial and all the comments before you start, and spread a white towel on the floor so you can find screws when you drop them. Watch this first -- http://www.youtube.com/watch?v=qiBxhA29e...
    kevicoll409 - Ответить
    The link above is no longer available.
    Kristina Graham -
    I will be buying a battery from you and using your instructions. I just installed a new CD/DVD using your instructions and 1) I feel like I owe you something and 2) Although more expensive, I have the confidence your battery will work. My current battery is the original with 1399 cycles in 7.2 yrs. A tech buddy had bought me a replacement and I installed it. I had just installed a new OS and the kernel_task went going nuts, using 90% of the CPU. Hours on the phone with Apple did not resolve the issue. On a whim, I put the old battery back in and Voila! But I cannot risk my battery swelling and going south on me. I am also going to buy your installation tools. Yeah, I already have them. But you can never have enough tools…or beer. And you don’t sell beer.
    Pete Banks - Ответить
    The instructions say that I am removing PH00 screws. I found that my MBP, mid ‘12, Retina has pentalobe screws instead!
    jsandersonq - Ответить
    This laptop definitely originally shipped with Phillips screws—but, Apple has been known to replace Phillips screws with pentalobes when one of their devices is brought in for service. Sorry for the rude surprise! Fortunately the correct driver is easy to find nowadays. [Blatant self-promotion alert!] If you support free repair manuals, consider picking one up from iFixit. Good luck!
    Jeff Suovanen -
    Me, too, and it’s plausible that this machine has been serviced by Apple in the past, replacing the screws as Jeff Suovanen suggests.
    iFixit shipped a pentalobe bit with the kit, but it’s too large for the actual screws, so it looks like I now need to get another bit. But what size?
    Jeff’s link is to a driver with a P5 bit, and that page links to a P2 screwdriver, but since I don’t know what size I actually need (and I don’t have a micrometer to hand) I’m reluctant to buy two on spec.
    Norman Gray -
    (The bit in the kit appears to be a P6, so I’m inclined to order a P5 and see what happens)
    Norman Gray -
    You’re using the wrong repair guide. This guide is for the 2012 NON-Retina MBP. You have a Retina MBP. The stock case screws in the 2012 NON-Retina are all Phillips, just as the guide says.
    Steven Wymor -
    To keep track of screws, I used the suggestions above by taping a photo of the lower case to a piece of corrugated cardboard and inserting/taping the screws in place. Also, as some have noted, the screws go back in at a slight angle; they are angled toward the center of the unit.
    Kristina Graham - Ответить
    If your vision, like mine, is getting too fuzzy to be able to distinguish between a tiny Phillips screwdriver and a tiny Tri screwdriver, there’s an easy way. With a Phillips (or a Pozidrive) you can get two opposite wings to reflect the light from a lamp or window straight towards your eye at the same time. With a Tri (or Penta) you can only get one wing to reflect at a time, however much you twiddle it.
    Alan Waller - Ответить
    There’s a very easy way to avoid cross-threading a screw thread, any size.
    Put the screw into its hole and start by turning it gently, slowly BACKWARDS. When you hear a little “Click!” sound, the male thread has just passed the opening in the female thread and is in exactly the right position to enter into it correctly when you start to turn in the correct forward direction.
    Remember, all drivers except hex (Allen key) and TorX need pressure to avoid slipping out and damaging the head. So even when you want to turn it in with LOW moment/torque, keep the CONTACT PRESSURE high.
    The keep the pressure on is on point. In my case once I loosened my first screw I thought I could relief my initial pressure. It was a mistake. I was doing the whole thing very slowly as a precaution. That helped me notice that the Phillips screw driver was sliding up out of the screw head. Not being sure why, I put pressure back on the screw driver until almost all the screw was out of the hole. Once out, I examined closely to find out that the threads have some sort of coating. It looks to me like some kind of locktite. Then I understood the importance of keeping the pressure on all the way through. It made me uneasy having to keep so much pressure on such tiny screws, but I found it was the only way to prevent damage to the “slots” on the heads. Anyway, all of them suffered some degree of damage, but I was able to successfully remove them and reinstall all of them back in their original holes.
    Martin Mejia -
    After reading this page on iFixit several times, I just could not face all the work of replacing the Logic Boards on two MacBookPro 2011s even if I was prepared to pay approx 400 USD (which I wasn’t). Then I read the reviews of a couple of folks who’d stripped down their machines and put their logic boards in the oven and, it worked! I wondered, if I just used my new Steinel Hot Air Tool (heat gun in my language) recently delivered from iFixit, on the logic board in-situ, without removing it? So I removed the battery, hard drive, and RAM and unplugged all the leads I could see WITHOUT removing anything else physically. Then using the 500 degrees set on the gun (setting 2) I ‘played’ the gun over the logic board for about 60 seconds on machine one with the restart problem (plus latterly, not completing start-up). Long story short… it worked! I spent a long time getting the s/w to load, but the commentary is too short to let me relate that part… ping me if I can help you do the same! blackaye@gmail.com
    Ian Black - Ответить
  2. Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive: шаг 2, изображение 1 из 1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
    What is the maximum amount of RAM that can be installed in this MacBook?
    michael - Ответить
    16 GB is the max
    Bradon Kelley -
    I can’t get the back panel off !! Removed all 10 screws but the panel is still on. Not a quick easy lift like in the picture of videos on youtube what going on…are the hidden screws locking tabs?
    Tachyon - Ответить
    Solved the tabs were hard to get off to the point I thought I was going to bend the back case off before it would let go.
    Tachyon - Ответить
  3. Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive, Battery: шаг 3, изображение 1 из 1
    • Remove the two 7.4 mm Tri-point screws securing the battery to the upper case.
    • Note: For certain repairs (e.g. hard drive), removing the battery is not necessary but it prevents any accidental shorting of electronics on the motherboard. If you do not remove the battery, please be careful as parts of the motherboard might be electrified.
    • You do not necessarily have to follow steps 3-6 to remove the battery in order to replace the hard drive. However it is recommended to remove all power sources from electronics before working on them.
    A 1/16th flathead screwdriver easily removes the tri-wing screws in this step. I could not find a Y0 Tri-wing driver at any local stores.
    Jon Daniels - Ответить
    I'd like to add that for me, a 1/16th flathead screwdriver did NOT allow me to remove the tri-wing screws holding the battery in place. After several careful attempts, it became obvious I was perilously close to stripping the screw(s), so I abandoned the attempt to unscrew the tri-wing screws with a flathead screwdriver altogether. As it turned out, I didn't need to remove the battery to do what I needed to do (keyboard replacement), but it would have been a whole lot easier had the battery been easily removable.
    dave - Ответить
    The Tri-wing screw driver is impossible to find in retail, amazon and ebay are great bets but they vary wildly in quality... I ordered two, and both were so cheap, and barely got the job done. It could be worth getting it here. When you do get it, make sure you push, the Y0 screws were very tight in my macbook, pressing hard prevents you from stripping the Y screw.
    Abe - Ответить
    I believe they are Y1 screws, no?
    Mark -
    What worked for me was actually a set of needlenose pliers - the heads on those screws aren't flush, they actually stick out enough that it's possible to turn them from the outside. Caused some scuff marks on the finish of the screws but it's not like anyone's going to see them anyway!
    oboewan42 - Ответить
    A tri-wing screwdriver sold as 'for Nintendo Wii' marked 'HFA 360/ x50' did the job. I replaced the screws with standard-head M2x6mm metric screws (M2 = 2 mm thread, 6 mm length of threaded part). Exactly, I took them out of an old hard-disk (with torx head and slightly shorter).
    akronymus - Ответить
    I had a cheap Tri-wing screw driver. The one that comes with the “Newertech“ battery. It did not make the job and it rather damaged the screws. Panic! I decided to buy the screwdriver sold by ifixit, the German one, not the other. At any point did I want more surprises. Yes it’s pretty expensive, but equally useful even with the screws already damaged. Thanks guys!
    Raul Roman - Ответить
  4. Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive: шаг 4, изображение 1 из 1
    • Use the tip of your finger to carefully peel back the corner of the warning label to reveal a hidden Tri-point screw.
    • Remove the last 7.4 mm Tri-point screw securing the battery to the upper case.
    Is removing the battery necessary?
    bname - Ответить
    It is not strictly necessary. As mentioned above, removing the battery is the only way to be sure that no parts of the logic board are electrified. It is very easy to replace the hard drive without removing the battery, but it is safer to remove the battery first.
    Daniel Brauer -
    Note: removing the battery can cause a hitch with OS X 10.9 Mavericks installation to a blank drive, or at least it did for me.
    Disconnecting the battery makes the hardware clock reset to something like Jan 1, 2000. This causes the Mavericks installer to fail its self-check with the error message: "This copy of the Install OS X Mavericks application can't be verified. It may have been corrupted or tampered with during downloading."
    To fix this, you need to open up Terminal from the Utilities menu in the bootable OS X installer environment and use the `date` command to set your Mac's clock back to the correct time before proceeding with the "Install OS X" menu selection, as described here: http://blog.mconserv.net/2013/10/install...
    Andrew Janke - Ответить
    Thanks for that warning, Andrew.
    Max Fenton -
    Happened here too, thanks for the tip!
    Franco Bianchi -
    As a note, my Mid-2010 Unibody Macbook did not have this third screw, just two to remove the battery.
    Max Fenton - Ответить
    Can anyone answer this question. I cannot afford the entire 80 dollar repair kit listed here and the tools needed only list a spunger t6 and a phillips...it appears from some of these comments there are more drivers needed. I am afraid to do this anyway but not having the right tools off the bat will just make things more difficult while waiting for an order to come in...can someone list the exact tools I would need ? Any help would be appreciated...I am ready to order this but want to put in one order....ifixit, can you clear this up perhaps ?
    laurie - Ответить
    One of the most important tool you should get is the head strap magnifier with lighting, it will make your viewing and capable ability much more confident.
    James -
    Taking the battery out is the easiest part once you have the Tri-Wing screwdriver
    Tri-point Y1 Screwdriver
    Tao - Ответить
    And yes, taking the battery out does naturally make the hardware clock reset.... It's easily fixed. See Andrew Janke's comment above.
    It's a small hassle, compared to needing to possibly replace your logic board because a surge from your battery fried it.
    Tao - Ответить
    Ne trouvant pas de tournevis Y1, j'ai utilisé avec succès une pince électrique à bouts fins pour déserrer la vis puis j'ai terminé avec un tournevis plat très fin (1.5x35)
    Ivan Keller - Ответить
    new battery drains at the rate of about 10% a minute. i may have received a faulty one but i wouldn't have bought it if i knew what i know now.
    aozoren - Ответить
    Is this a battery from iFixit?
    Scott Dingle -
  5. Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive: шаг 5, изображение 1 из 2 Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive: шаг 5, изображение 2 из 2
    • Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case.
    • Do not try to completely remove the battery just yet.
  6. Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive: шаг 6, изображение 1 из 1
    • Tilt the battery away from the logic board enough to access the battery cable connector.
    • Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
    • Pull the battery cable connector away from the center of the logic board.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
    I'm having the same problem as previous commenters: the battery now drains much faster. It's the original factory unit—I only replaced the HD, which is working great.
    Is there something I am missing with the battery reconnection? Maybe it's loose?
    I just want to make sure before I crack open my laptop again.
    cmalec722 - Ответить
    Fast battery drain problems might be due to a corrupted power manager circuit on the logic board. To reset it, remove the battery, press the power button for about 5-10 seconds, then reinstall the battery. I know the problem might have been partly due to removing the battery in the first place, but this is the procedure for resetting what might have gone wrong. It might also help to do a PRAM reset, by holding down Command-Option-P-R at power (not just from a restart), and let the Macbook chime twice after its initial powerup chime.
    johnsawyercjs -
    The spudger works well for detaching the connector.
    skat1140 - Ответить
    I’ve done a few of these and it should be noted this connector is a very firm fit. Using the flat end of the spudger to pry alternately at the protruding sides can be helpful.
    py - Ответить
    Buen tutorial, solo advertir una cosa: los tornillos de la batería (Tri-point), en mi caso estaban muy duros.. atención si se usan destornilladores baratos.. mucho cuidado porque puedes dejar el tornillo imposible de extraer..
    fserranolv - Ответить
  7. Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive, Optical Drive: шаг 7, изображение 1 из 1
    • Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up off the logic board.
  8. Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive: шаг 8, изображение 1 из 1
    • Disconnect the camera cable by pulling its connector away from the socket (toward the optical drive) on the logic board.
    This step is optional. If the cable is to hard to remove, you can just leave it connected and just make sure the cable stays on the side while you remove de optical drive.
    Bernak - Ответить
  9. Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive: шаг 9, изображение 1 из 1
    • Use the flat end of a spudger to pry the optical drive connector up off the logic board.
  10. Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive: шаг 10, изображение 1 из 2 Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive: шаг 10, изображение 2 из 2
    • Remove the two Phillips screws securing the AirPort/Bluetooth board housing.
    • Carefully rotate the AirPort/Bluetooth board housing (with AirPort/Antenna cables still attached) out of the lower case.
    Be extremly carefull while unscrewing these screws. They are made from a more delicate metal than the ones on the outside of the Mac. If You bought the 54 piece set available on Ifixit - be warned - the phillips screwdriver caps do not do the job, and You should have a "shallower" phillips screwdriver here.
    michalwoloszanski - Ответить
    Hi guys - this is the second last remaining screw (last one is underneath the board housing at the far corner as seen in Step 11) that's in my way before I can remove the CD-drive.
    I believe I've used a wrong Philips screwdriver and now the screw itself has lost it's groove.
    Problem is - the screw is really tight (first time opening up this particular MBP) - is there a way in which I can "extract"the screw?
    Thanks.
    theimperialdragon - Ответить
    Did you ever figure this out? I'm facing the same issue.
    William Kuan -
    This is my second time installing a hard drive into the optical bay of this model MacBook Pro. I’d forgotten the nightmare I had last time when I stripped the screw. I had to drill it out using an electric drill and drill bit. It did the job. What it basically did was take the head of the screw off and leave the rest of the screw stuck in the hole. It worked but it was pretty terrifying going at your macbook with a huge power tool. I was able to remove the part and fit my drive. I couldnt replace the screw though but ive never had a problem from it and its been a few years at least.
    So, I just got to this screw again on my second time and got the same problem. I watched a few youtube videos and this one helped.
    https://www.youtube.com/watch?v=7WHgxcbI...
    yumyab - Ответить
    (Continued from above)
    The guy is saying that if you use a different type of drill bit (left twist rather than the usual right twist) then you should be able to remove the screw completely and then be able to replace it with a new one. I dont have a left twist drill bit so I thought it should do the same job to set the drill to the opposite spin. Tried it and it did the trick! The screw is out completely.
    Thank god this screw isnt on the logic board!!!
    yumyab - Ответить
    I think that it’s too different size of screw. The tutorial don’t add more details, but one is longer than the other one. I suppose that’s why people get trouble to screw out.
    Victorien - Ответить
    Set these two screws in a special place. I use a loop of masking tape on my workdesk. They heads appear identical but the size and thread are very different to all other screws in this procedure. Trying to use one of the other similar-appearing screws will be annoying if not damaging to its threads.
    py - Ответить
  11. Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive: шаг 11, изображение 1 из 1
    • Remove the following three Phillips screws securing the optical drive to the upper case:
    • One 4.5 mm Phillips screw securing the optical drive bracket to the upper case near the fan.
    • Two 2.5 mm Phillips screws securing the optical drive to the upper case near the optical drive opening.
    These screws actually use a #000 Phillips bit. The kit for this repair comes with everything you need *except* that. The difference between the two bits is night and day. I'll bet some—maybe even most—people can unscrew them with the included #00 bit, but mine were seated pretty firmly. With work, I got two of the three out. I nearly stripped the last one beyond use before I went out and bought a new bit to try. I'm not sure how to suggest adding that size bit to this guide, but I think that should maybe happen.
    When getting back to this step for re-assembly using the dual HD housing, just know that the screws might not actually fit. I found that the heads of the screws were actually too big to fit flush against the housing. So I only used two of the three screws to re-mount. One of them is at a bit of an angle, too.
    Overall, I am still happy with this whole setup.
    dentondon - Ответить
    The two 2.5mm screws circled in orange are close to impossible to put back in due to the deep inset of their mounting tabs. Either use the tiniest dab of grease to adhere them to the tip of your 000 Phillips driver or magnetize the screwdriver.
    py - Ответить
  12. Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive: шаг 12, изображение 1 из 1
    • Lift the optical drive near its connector and pull it away from the upper case to remove it from the computer.
    The biggest problem I had with re-assembly was getting the two 2.5mm screws back into position. My driver is non-magnetic so the screws would not ‘lock’ in place on the 000 driver. I ended up with a tiny piece of Kleenex to wedge the driver into the screw and then carefully removing the tissue after the screw was in place.
    damaclac - Ответить
  13. Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive, Optical Drive: шаг 13, изображение 1 из 1
    • Pull the optical drive cable out of the optical drive.
    • Be sure to pull by the edges of the connector, not by the cable itself.
    • Optical drive remains.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
  14. Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive: шаг 14, изображение 1 из 1
    • Remove the two black Phillips #0 screws securing the small metal mounting bracket. Transfer this bracket to your new optical drive or hard drive enclosure.
  15. Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive, Dual Hard Drive: шаг 15, изображение 1 из 2 Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive, Dual Hard Drive: шаг 15, изображение 2 из 2
    • Remove the plastic spacer from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
    is it 9,5mm or 12,7mm for the caddy? My stuff macbook pro mid 2010, need advice what size is compatible. Thank you
    Adi Purba - Ответить
    All Macbooks use 9.5mm Optical Drive Caddy, also, If you’re wondering as well, the Optical Drive runs at SATA II speeds just like with the main hard drive area, so if you’re using a SSD, then it’s going to run at a slightly slower speed.
    - PS5iscool - - Ответить
  16. Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive: шаг 16, изображение 1 из 3 Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive: шаг 16, изображение 2 из 3 Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive: шаг 16, изображение 3 из 3
    • Make sure that the hard drive connectors are facing down before placing it into the enclosure.
    • Gently place the hard drive into the enclosure's hard drive slot.
    • While firmly holding the enclosure in place with one hand, use your other hand to press the hard drive into the enclosure connectors.
    Okay it seems like some models of MacBook Pro have issues with a fast (6Gbit/s) SSD in the optical bay. Even though my Mac says it offers 6Gbit on both bays it simply didn't work in the optical bay. So I switched places between the two drives and everything seems to work. My Mac booted from the old HDD in optical bay automatically and then I cloned it afterwards and changed the startup disk to the new one. As said before, don't put a fast SSD in the optical bay!
    Carl - Ответить
    This is an extremely late response to an old comment, but… whatev’s. My 2011 MacBook Pro had that issue: the main (HDD bay) SATA operated at 6Gbit, and while the optical bay said it was 6Gbit, the “Negotiated Link Speed” was like 1.5Gbits regardless of what you put in it (I can understand 1.5Gbits for an optical drive, but not for an SSD). Some of the early 2012 models did the same thing, from what I understand, but that was corrected pretty early on; both my 13” and 15” 2012’s run at 6Gb/s on both SATA busses.
    AJH -
    It’s not wise to swop the optidrive for an HD as there is no physical protection. The caddy is only intended for an SSD.
    Ben Ormerod - Ответить
  17. Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive: шаг 17, изображение 1 из 2 Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive: шаг 17, изображение 2 из 2
    • Once the hard drive is snug, reinsert the plastic spacer while holding the hard drive against the bottom of the enclosure.
    Normally with the HD enclosure there come a set of screws. use these to screw down the HD in the enclosure since you need to flip it up side down to reinstall it into the MBP
    Bart - Ответить
  18. Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive: шаг 18, изображение 1 из 2 Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive: шаг 18, изображение 2 из 2
    • Use two Phillips #1 screws to secure the drive to its enclosure.
    Where are these screws coming from? Were they part of the original optical drive?
    Bradley DeHerrera - Ответить
    The new enclosure should include these two Phillips screws.
    Sam Omiotek -
    Can someone show the step of removal process of hdd/SSD placed in the caddy? I am unable to revert this process. Do we have to apply back greater force to remove back the hard drive/SSD from the caddy?
    Tarun Kumar Verma - Ответить
    Gads, I wish they made a caddy where the optical drive was removable without having to remove the entire caddy. That is a major peeve of mine. Like… just mount it the other way! I don’t want to have to go through this entire process every time I upgrade the secondary drive.
    AJH - Ответить
    These screws seems to be located in different places on different enclosures. I had serious trouble getting the SSD that the previous owner of this MacBook installed out of the enclosure until I realized the screws holding the SSD in place were on the side and not on the bottom. In case anyone else has the same issue!
    nessie1001 - Ответить
  19. Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive: шаг 19, изображение 1 из 1
    • Attach the optical drive bracket to the new enclosure with two Phillips #0 screws.
    • Reconnect any cables you have removed from the original optical drive onto the optical bay enclosure.
    Replaced the optical with hdd, as well as replaced the hard drive with an ssd. Now I get the circle with a line through it. But, when I hold the option key down, it gives me both hard drives, PLUS, the thumb drive I have in the USB port with a Mountain Lion installer. It even shows the recovery disks, but gives me the circle with the line when I choose one. Any help is appreciated.
    claude - Ответить
    Mate,
    My mbp shipped with OS 10.8, and I had upgraded twice to 10.10
    I've a 10.7 USB which upgraded my old MBP.
    My plan today was to boot with my new ssd, my time machine back up and the Lion usb plugged in.
    I would then click on the Lion usb, and tell it to put the OS and time machine back up on the ssd.
    So I help down ALT and when it started it gave me the options of the usual Mac internal or the Lion USB.
    I clicked Lion, but instead of taking me to the install options (Disk utility, restore from time machine etc etc) it gave me that grey circle with a diagonal line through it. The no entry sign - grey on grey - that I think you have.
    Some googling said that it is because I was trying to usb a 10.7 install on a MBP that shipped 10.8
    You can't go back, apparently.
    So if any of the OSs are older than the mac you got, you will get this error. The grey in grey no entry.
    I just cloned my HDD to my ssd (Carbon copy cloner free 30 day trial) using an external stat-usb3 wire and all is good.
    Rory -
    I have a 17" Macbook Pro6,1 unibody with an Intel Core i5, 2.53GHz. I was successful installing a 250GB SSD in the DVD bay, and I'm able to boot from it. I did this by first installing OS X 10.9.4 on the SSD mounted into an external HD case, testing the system to see if it would boot up into the SSD, then installing the SSD and carrier in the DVD drive bay. The system now boots up from the SSD with no problems. If you are having installation problems, I recommend trying this method.
    roger hall - Ответить
    I just have finished installing second SSD to my MBP (unibody 15` 2010).
    First one was changed like one year ago. Samsung 500GB SSD. It is in my HDD bay and I'm running system from it.
    Today I put a new Samsung 1TB 850 Evo 1 SSD in to my optic bay.
    I encounter problem with SSD not recognized by Finder.
    But It was recognized by Disk Utility.
    What I did was I erase new SSD by Disk Utility. Then the new partition was created and now It has been seen by Finder.
    So If you see it in Disk Utility just erased it.
    Some extra info in under this link--> https://discussions.apple.com/docs/DOC-4...
    Wish you all luck :)
    rybafly - Ответить
    My installation went great thanks to the guide. I did notice a small thing that might make a good tip, and that is to inspect all the visible screws. I saw one that was slightly raised, and when I poked around with the spudger, I found 2 more that had worked themselves out a bit. Its probably something super rare but at the age of these things, it wouldn't hurt to check.
    Tineyi Chapisa - Ответить
  20. Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive: шаг 20, изображение 1 из 3 Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive: шаг 20, изображение 2 из 3 Installing MacBook Pro 15" Unibody Mid 2010 Dual Hard Drive: шаг 20, изображение 3 из 3
    • Don't ditch that drive! You can still use your optical drive externally with the help of our SATA Optical Drive USB Cable.
    • Align the cable's SATA connector with the drive's port and plug in securely.
    • Plug the USB connector into your laptop and your optical drive is ready for use.
    There is a small metal button in the front of the drive and you can use that to eject the drive if you were wondering.
    Joseph Landry - Ответить
    Maybe that explain the eject button mechanism maybe….
    Die neue SSD wurde durch das Laufwerk ersetzt aber leider wird jetzt die alte HDD nicht mehr erkannt. Hatte schon ein anderer das Problem?
    Alexander Richter - Ответить
Заключение
131 участников успешно повторили данное руководство.
Brittany McCrigler
Участник с: 03/05/12
89 012 Репутация
Автор 131 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 767 руководств
7 Комментариев
Step 8: The cable needs quite a hard pull to come out, be careful to pull straight! When reconnecting I used 2 wooden sate stick to push the connector back in.
Now running an sad for startup and the old HD as capacity storage. Thanks for the great manual on how to do these!
Bart - Ответить
After finishing this guide, it occurred to me to test out a little known feature in MacBooks...
The MacBook has sensors that detect motion. When the sensors detect motion that is violent enough to risk damaging the spinning hard drive (and it doesn't have to be much), the head gets temporarily disengaged from the disk so that the risk of damage decreases. If you ever pick up your laptop quickly and hear a click, that is what is happening.
After installing a hard drive where the computer only ever expected an optical drive, that safety feature is lost. Now when I pick up my MacBook when the drive is spinning, there is no click. I put an SSD in place of the old drive, so I can't confirm if it still works in the actual hard drive area of the computer... but the one in the optical drive area definitely no longer can protect itself from rapid movement.
Still a fantastic upgrade, but remember to treat the hard drive in the optical bay as slightly more prone to failure than before.
The fact that we can still use the optical drive (step 20, now external) is nice, but I would like to put it into some enclosure/caddy/case as well instead of having it bare naked . Don't you sell anything for this?
Alexandre Drouin - Ответить
Great instruction found it very useful and worked for me all the way. Thank you
Ishaaq Ahmed - Ответить
Hi there,
I followed the guide without problems but weeks after that I am experiencing sudden reboots when there is a change in the Graphic card (even when using forcing programs as gfxCardStatus). After looking for many patches or updates, I think it may be a problem of the SSD (a Crucial BX100 250gb), but I wanted to ask you first if anyone have had this same problem and if there’s any recommendation before buying another SSD drive.
Hug - Ответить
i suggest looking into replacing the logic board if you have a integrated graphics card and a discrete graphics like a second one ( i have a NVidia GeForce 330M) the laptop may start to have problems when it tries to dynamically switch between the two this is a kernel panic shutdown search on appledollars.com for more information of course you can visit your apple store
Chris Samuel -
Hello Hug,
It has nothing to do with the SSD or hDD drives. It’a an issue of faulty capacitor on the logic board.
You,ve had probably resolve all your problem by now, hopefully. Nonetheless, the graphic card issue is well documented on the net. As for myself, I’ve repaired the capacitor on my logic board as suggested by Louis Rossmann in NYC. A year from now, my computer still works flawlessly !! I would say the repair was easy, just a tad of patience and some luck. The contacts are beneath the capacitor, witch make it uneasy to solde on the board, thus luck is probably involve here. I couln’t imagine throwing my computer away considering the cost on a 2,50$ capacitor ! To say, you don’t need to replace the logic board, just repaired it. Good luck.
Regards, Louis from Montreal
louisprudhomme -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 25
За последние 30 дней: 79
За всё время: 95,979
